Last thing tonight. Now that all is done underneath, it was time to trim the top so the outside handle will fit. First I fit the trim on top then placed the Nylon washer on then placed the handle down on the shaft. The handle is about 1/8" high. I trimmed off a little more than 1/8" from the shaft and the handle just rides on the washer. A hole will be drilled it the front of the handle so that a set screw can be added. Nuff for now. Good Night!!!
