Tonight I positioned the Rear anchor blocks behind the slide rails. I first measured in 1/8" from the fuselage. This clearance is for the rivets heads on the side skirts. Also, make sure the forward hole is forward enough to clear the F-705 bulkhead that is below it. Measure 13/32" from the rear of the bulkhead, draw a line then you can see how the forward hole needs to be less than 5/16" from the edge per drawing 41. Look at DWG 42 to get the bulk head clearance measurements. Secured with AN3-5A bolts, washers and nuts. Oh, I decided not to drill the side holes since I wasn't sure where the pin was going to come down. This can be done later.
Drilled #40 holes first.
Hard to see but the top bolt is almost to the edge. Still plenty of edge clearance.
My next step will be to measure and drill the Anchor blocks.
