"THE OTHER WOMAN"
Date:  7-31-2005
Brief Description:  Fule line through fuselage
Now that the Fuselage is back down on the hourses I took the time to isntall the Fuel line fittings that connect to the tank fitting. I built up a stand for the Band Saw and wacked off the extra steel braided line and cranked on the fittings. Time to install another new Band Saw blade. It is well worth the 4 bucks for waisting a blade to cut these aeroquip lines. It makes this process a breeze.
Moved the Bandsaw in palce and cut off the extra line
Fitting installed.
Fitting installed.
Other side done.
Other side done.
