"THE OTHER WOMAN"
Date:  2-21-2009
Brief Description:  Started 2009 Conditional Inspection
This is my first conditional inspection. I will be starting with the F/W forward. I want to break the inspection down into areas so the plane wont be down for long. Pulled the cowl to do the Oil change and filters. I removed the carb screen and found just about nothing in it. I first drained the bowl to remove all the fuel and then bent the tabs back on the Inlet screen gasket. Came out without a hitch. Blew it out with some air and back in it went.
