Like I mentioned when I first installed the Nose wheel tube. The tire kept going flat so I pulled it apart. I pinched the tube and BOY did I pinch it. The second time was easier because the rim was already compressed on one side of the Rim and I was able to hold the rim tight together while tightening the Bolts. As of 7-12-05 no leaks noted.
