Took time out from the Canopy to design and contruct the Fuse drop down panel. This is not something that is provided with the kit because there are so many variations for the Electircal systems. Since I am going the Fuse panel route and not the Breaker way, I decided to build a hinged drop down panel for at least two of the blocks. The other fuse block (Always Hot) will be mounted to the sub panel above this drop down panel. I need to find a Camloc that fits this as apposed to a Screw and nut plate.
First I figured how close I could come to the outboard side without hitting the Vent tube.
The panel is about 8" by 9". Cut the hinge to size
Drilled the holes to the sub panel and test fit the fuse blocks.
