The reason I removed the connector off the LSE box was so I didn't have to make a large hole in the firwall. The connector comes intalled on the wire that goes from the crank sensor to the LSE box.
It starts here as the circuit board at the crank sensor
Then folows the engine along the starter wire then up through the FW
Then makes its way to the back of the LSE ignition box
