Tonight I finished up wiring the Manifold pressure sending unit. It takes three wires from the Dynon EMS-D10. Ground, MP and 5 Volt excitation circuit. This is a 5v circuit from the EMS and is used in other areas like the MP, so I made a termination block and brought in the 5 volts then daisy chained it then wired in the MP white/red lead. Now I can just wire off this block for future circuits.
5v excitation block on the left and the MP sensor on the right with the three wires at the bottom.
