Wired up the Main Buss to the Battery Selenoid. This is a 6AWG wire which I ran to the lug on the ANL fuse instead. Same thing as wiring to the side of the Battery Selenoid only alot easier. Once the Battery switch is on the Selenoid will energize and power will flow to the right side of the contactor then power will be supplied to the the Main Buss.
This is the end that should have been on the Main Buss not the Avionics Buss. I moved it.
The 6AWG battery wire runs along the fuselage then through the F/W
Then down the Battery cable (Not in place yet) to the Selenoid Circuit.
