Here we go!! One wire at a time. Starting with the Ground wires from the Radios and Avionics. Each wire gets a name heat shrunk to the end of the wire. These are fast-on connections that are very tight. Every electronic device in this bird gets a separate ground wire all the way back to the wirewall ground block. This should eliminate any grounding issues and interference in the radios.
Hard to see the markers on each wire. They are facing down so I can see them from the cabin floor.
