Riveted the last part of the Canopy deck and put a coat of primer on to match the rest of the Deck. Also cut the Canopy rail so that it will not touch the Canopy skirt as it slides rearward. The front is set in a 1/16" and the rear is flush with the fuselage.
The only thing left was the top rivets. -4's and 3's
Here is how the C-657 is cut to plans
You cut it as needed to clear the fuselage. I put a straight edge up the side for clearance.
