Brief Description: Rivet the LT 757 to Canopy deck
Away for a couple days for my Niece Tressa's wedding. Had a great time. Took time tonight to work on the Canopy deck area. This needs to be completed before the Canopy rail is drilled in place. If your installing a Slider and you have a QB, the 705G bracket needs to be removed. Then I drilled out the 705D to 705F channel. I riveted the two in the required places. Then I finished drilling holes in the 757 brace. The longeron needs three holes in addition to the ones the QB had.
After riveting the 705D to the 705F I clecoed the 757 to the longeron.
Match drilled the new holes on the rear of the 757.
Removed and cleaned up. I also counter sunk the three rear holes.
