Once you get the fit right you drill out the three holes and put it back in and mount it to the panel. With the mount bracket installed I made some marks through the holes that were already cut in my QB fuselage. This is just to see how the bracket lines up. Mine was fine. I went ahead an match drilled the holes through the side of the fuselage through the mount bracket.
