Today I riveted the support bracket for the forward deck ribs. There is an angle that runs the length of the center rib from the Firewall to the top right behind the Instrument panel. This gives the entire deck the needed support to hold up everything. There is a washer (-6 which I made because I didn't have any that small) behind the bracket towards the top. This holds the bracket away from the RIB for the Roll bar center brace can slip down in between the bracket and the Center rib. The Roll bar brace then gets bolted in place.
Added one of the brackets
There is a washer (-6) behind the bracket towards the top. This holds the bracket away for the Roll ba
