Anyone curious of what a MAC Servo looks like inside. I needed longer wires to come from the servo through the Rib and over to the Terminals, so I pulled the Aileron Servo apart and went through my normal anxiety attack when you first bite off something that you can't or thought you couldn't do. After calming down I started taking it apart. It wasn't as bad as originaly thought. Getting the wires tucked back in was a little tough but after a few times of screwin around, it fell into place. The first problem I ran into was when I shut the case and ran it through its range it wouldn't go back in the other direction. Come to find out the the switch was shutting down one direction because the solder was to large. FIxed that and all is well and I have plenty of wire to reach the Terminals.
Here is the block with some of the terminals attached.
