"THE OTHER WOMAN"
Date:  1-28-2006
Brief Description:  Throttle/Panel bracket
Tonight I mounted the Control quad to the panel. As talked about previously, the Quad bracket will serve two purposed by holding the Quad and stabilizing the bracket that firms up the sub panel. As you remember I cut a hole in the sub panel for the SL30 and SL40. Richard C. and I pondered this one for some time before we went with this process.
Mounted the Brackets on the outside for more stability.
Underside towards the sub-panel
