The next few pages are pictures of how I finished up the trays. I pretty much just moved up the line with each tray. I made sure each was flush with the next. I would bolt the one prior so the try would not flex and give me a false measurment. I then marked each hole with a marker from the inside of the tray then removed the angles and drilled the holes on the drill press. Remounted the angles, mounted the tray then moved on to the nixt. This took some time but the results were great.
