Installed the Fuse panel cam lock mounts. This was just a piece of alum bent so that the fuse panel will tuck up under the panel. There are two cam locks to secure it. It should be up enough so that no one will drag their legs across them. In picture two you can see the oiece of .020 alum I used to brace the radio stack. It runs from the top of the panel bracket down to the rear of the Transponder cage. I will also add a brace to the sub panel to even give it more support. Installed the Quadrant bracket to the panel. This mounts to the bottom of the panel which also has two angle braces running forward to the Sub panel. The Bracket on top is for the Carpb heat cable and the alternate air door cable for the carb.
