Inserted Drilling bushing (Made from alum tubes) so that the drill will line up when drilling through the bearing to the Elevator horns. Installed elevators and inserted bolts, washers (2 AN 960-416 and 1 960-416 L plus 1 5702-95-30 washer). This combin
Alum tubs inserted in bearing to hte Horn, Drilling through
After drilling just pull out the tubes
Installed the Elevators after final drilling to 1/8 inch holes
