Took a little time to fit the Emp fairing. Haven't worked with fiberglass yet other then cutting out the holes for the Wing tip lights. I used the Band Saw as much as possible but had to use the roto zip in tight spots. Just worked slowly and kept removing and installing till it fit good.
