Finished up sizing the Canopy latch handle. You first need to cut down the Canopy stem that the Handle slides up through. With the Canopy fully closed, place the handle up through the frame then mark the amount that needs to be cut off the frame. I measure it so the latch would just fit over the pin. Then I cut the end off the latch so it would not hit the front of the roll bar as it spins in the closed position. The inside of the latch needs filling so that when you latch the canopy it doesn't pull the canopy so tight that it bends any part of the frame. I have a little more to go but will leave it till the canopy is complete then I will go back and trim it some more if need be.
Measured for the spring holes
The spring holds the latch open so that it grabs the pin
