"THE OTHER WOMAN"
Date:  12-14-2007
Brief Description:  First Engine Run
Dick Czarnecki and I ran the Engine for the first time on 11/10/2007. We primed the Engine with the plugs out until oil came out of the Oil pressure line. Once everything was tightened up again, we took it outside and gave it a go. On the first attempt without Priming, it almost went but not. I gave it one shot of the primmer and it fired right up. Idle was 630 RPM. I ran it to 1500 RPM once or twice and the complete run was only a minute. Shut it down, checked for leaks. No leaks noted! Fired it back up and ran it for about 10 minutes. See it at www.youtube.com Search for "N607RV"
