"THE OTHER WOMAN"
Date:  5-28-2006
Number of Hours:  1.00
Brief Description:  Safety wired prop
Time to put some safety wire on the C/S prop bolts. There is a trick to this that will save you much time staring at it. If the holes point straight into the hub and you have a problem getting the wire through the hole, loosen up the bolt first then run the safety wire through the hole then go back and torque the bolt. Then you can do your thing with the safety wire.
