"THE OTHER WOMAN"
RV7A
Eyeball for CS cable
Drilled out the hole in the eyeball just under the size of the cable. When the Eyeball clamps down on the cable it will tighten up and hold the cable.
Drilled the hole in steps of 1/8" till the final size to fit the cable.
Installed the cable through the Hole.
Screwed the eye pieces over the cable and tightened up the nut.
RV7A Home
1335
A/C Hardware & Supplies
Airshow time
Baffles
Brakes
Cabin
76
136
133
Conditional Inspecti
Cowling
DAR Inspection
Elevator
Engine Run
97
Flying
195
Hardware
Horizontal Stabilizer
Inspections
Lights
Oil Cooler
Panel
Paperwork
59
Service Bulletins
Shipping
Sub Panel
Systems
TC Inspection
Travels
Vertical Stabilizer
Visit
Weight and Balance
Wheels
122
