I should have checked these holes before drilling the pilot holes. The plans state that you should get as close to the inside of the deck. After I fit the spacers up in there I found out that I just missed the inside of the Longeron. This will be to close since the hole will need to be opened up. I redrilled the holes closer to the inside. When I open the hole this will not be a problem. Fit the Roll bar in position and make sure of the distance between the Rollbar and the outside edge. This needs to be there for the canopy. Mine was tight but when I had one side clamped I was able to push the other into position.
Mis-marked holes. Redrilled.
Marked the line so I make sure to leave the correct 7/32" distance.
