"THE OTHER WOMAN"
Date:  7-8-2005
Manual Reference:  8-16
Brief Description:  Elevator Horn drilling
Aligned the Elevator and clamped them to the Horizontal stab. Find the horn that is further back and drill a pilot hole 1/2" back 3/8" up per the plans. Then mount the elevator back on and cut a block of Aluminum or hardwood to fit in between the horns and match drill it with the other. Open the hole up to fit the AN3-14A bolt.
Clamped the elevator to the Stab
Here is the hardwood block clamped and ready for #30 hole.
Elevator in trail and match drilled through the other horn.
