"THE OTHER WOMAN"
RV7A
Front Deck area install
Cut the angles for the upper panel supports. A notch in each one of them is needed to make the bend at the corner easy. There are holes in the panel that get matched with the angle.
Shows the cuts I made in the Angles
Cleco'd in place and matched drilled.
RV7A Home
1335
A/C Hardware & Supplies
Airshow time
Baffles
Brakes
Cabin
76
136
133
Conditional Inspecti
Cowling
DAR Inspection
Elevator
Engine Run
97
Flying
195
Hardware
Horizontal Stabilizer
Inspections
Lights
Oil Cooler
Panel
Paperwork
59
Service Bulletins
Shipping
Sub Panel
Systems
TC Inspection
Travels
Vertical Stabilizer
Visit
Weight and Balance
Wheels
122
