Finished installing the Brake lines in the Cabin. Things to look out for are areas where constant rubbing will happen. Like against the Steel Braided lines to the Parking brake. I had to redo one line cuz of this. You need to move the rudder pedals through full Left and Right before getting your line lengths.
Connected the lines to the Resevoir
This is how the lines get there compression fittings
Shot from the top. You can see how they would rub.
