"THE OTHER WOMAN"
Date:  1-8-2005
Brief Description:  Tank attach bracket
Needed drill out 5 rivets in the 902 bulhead. This where the bracket and angle will be riveted and bolted. The Angle and spacers are riveted back through the holes then two of the holes One excisting in the top and a new hole between the rivets is drilled
Drilled out the rivets.
Inside where the spacers and angle are going to be
