"THE OTHER WOMAN"
RV7A
Lt Step
Started work on the Lt step. Drilled out the holes just like the Right side. This one has a slight problem which I will show you in the coming pictures. There is a 3/16" gap between the end of the tube and the Floor rib.
Drilled the holes for the outside mount brace
Tube running through the floor ribs.
Me making fine adjustments.
RV7A Home
1335
A/C Hardware & Supplies
Airshow time
Baffles
Brakes
Cabin
76
136
133
Conditional Inspecti
Cowling
DAR Inspection
Elevator
Engine Run
97
Flying
195
Hardware
Horizontal Stabilizer
Inspections
Lights
Oil Cooler
Panel
Paperwork
59
Service Bulletins
Shipping
Sub Panel
Systems
TC Inspection
Travels
Vertical Stabilizer
Visit
Weight and Balance
Wheels
122
