Back to the steps. Bent the step bracket where it meets the fuselage on the rear side. You can see in pictur 2 that the fuselage tapers back at that point on the step. Took a Adjustable wrench and bent the flange after trimming some off on the grinder. Th
Trimmed and bent
Clecoed after setting up the hole patterns.
Put some tape behind because of all the scratches.
