Brief Description: Attaching Fwd and Aft Spar to Spar Cap Assembly
Completed Steps 1 to 2 and part of step 3. Cleco'ed the HS-01202-1 Fwd Spar and HS-01203-1 Aft Spar to the Spar Cap Assembly to create the Spar Box Assembly. Riveted the outboard HS-01233 Horn Attach Angle to the aft Spar using 4 LP4-3 rivets. Cleco'ed the HS-01232-1 Horn Doubler and WD-01207-1 Upper Horn to the fwd spar and HS-01211-1 Spar Cap, aligned fwd holes in the horn laterally with the #30 holes in the fwd spar while cleco'ing in position. Clamped the horn to the horn attach angle.
