Completed steps 1-8: Machine countersunk the HS-01231A-1 Hinge Angle per Figure 1 call-out all #40 holes for AN426AD3 Rivets. Separated the Hinge Angles into 4 parts. Deburred holes and edges and primed using Aviation Primer Zinc Phosphate. Riveted together two Inboard Hinge Bracket Assemblies using 1 HS-01231A-1 and 1 HS-01231B-1 and 4 AN426AD3-3.5 Rivets Each. Riveted together two Outboard Hinge Bracket Assemblies using 1 HS-01231A-1 and 1 HS-01231B-1, 1 K1000-4 Nut Plate and 2 AN426AD3-3.5 Rivets and 2 AN426AD3-4 Rivets Each.
Separated the HS-01233 Horn Attach Angles into two Horn Attach Angles. Machine Countersunk the #40 holes in the HS-1209 Spar Cap Spacers per the figure 5 call out and then separated the 8 spacers by removing the material in between. Deburred holes and edges and primed using Aviation Primer Zinc Phosphate.
Prepared the HS-01212-1 inspar ribs and the HS-01211-1 Spar caps by deburring edges and priming using aviation primer zinc phosphate.
Cleco'ed the spar cap spacers, HS-01212-1 Inspar ribs, and the two HS-01211-1 Spar Caps together as shown in Figure 6.
