Brief Description: Left Wing - Root Upper Skin and Root Nose Skin
Left Wing
Strapped the Wing Nose skin in place and cleco. Did this so that the #1 Nose Rib could be fitted with the Rib Upper Skin stiffener. Once in place drilled out the Rib Upper Skin stiffener to the Wing Nose Skin to #30 and cleco in place.
Drilled out to #30 and cleco in place the bottom side of the Root Nose Skin. Then worked at fitting the Root Nose Skin around from the bottom to the top. Tried several strapping techniques to hold skin in place but could not get a good fit of the Root Nose skin all the way around to the upper spar. Worked with Rib Upper Skin stiffener to get the proper angle for the Root Nose skin.
Decided to hold the final fitting until later. Remove the Root Upper Skin and Root Nose Skin and set aside.
