LARRY'S WEB SITE
CH-750
75-WA-1
Left Wing Skeleton
Worked on Left Pilots wing. Located and mounted all nose ribs and wing ribs.
Drilled out and deburred all nose ribs and wing ribs to A5.
Also drilled out and deburred all right nose ribs and wing ribs in prep for right wing.
Located the tie down rign. Drilled out to A5 and set aside.
Located the I/B rear channel, O/B rear channel, rear upper strut fitting, and rear channel doubler . Clecoed and drilled out to A5.
Located rear root doubler. Installed and drilled out to A5.
Mounted the rear channel to end of wing ribs. Drilled out to A5.
Located and cleco the root wing rib.
Left Wing
Left Wing
CH-750 Home
126
Horizontal Elevator
Horizontal Stab
