Built the doubler and fitted the wing skins to the right wing. All skins drilled to #40. Leading edge assembled and skin was drilled to the spar and ribs. Built the W423 splice plate and drilled the T712 Z brackets to the spar. * Still need to drill the leading edge ribs to the spar*
