Brief Description: Final leak test for R fuel tank
Sealed the exterior baffle joint and checked the entire tank at .6 psi, no leaks! Installed the tank on the wing and torqued all bolts to 25 in/lbs and applied torque seal.
Wing was moved to the cradle and then took the wing stand down. Thats been a long time coming.
