Match drilled C702 skin to WD716 frame Drilled Canopy Hinges to in place Opened canopy hinge holes to 3/8 and pressed in bushings Re-installed WD716 Made C614 Canopy splice plate Match drilled, countersunk and riveted splice plate to WD716 Made C723 wedge spacers Made C613 canopy frame splice plates left and right Fit and set Canopy side frames WD725 with C613 and C723. Clamped and match drilled in place
