Brief Description: getting the twist out of the rudder
i noticed that the rudder was twisted.. when i would hold down three corners of the rudder to the 2x4's that it was supported by, the 4th corner was off the 2x4's by a couple inches.
took out all the cleco's from one side. held all four corners down.. pushed the skin down.. saw which holes lined up OK.. cleco'd those. there were a couple which did not line up -- these were causing the problem. so i redrilled a couple.. maybe 2 or 3 holes.
a couple holes ended up being enlongated because of this.. I still filled them with A4 rivets as they werent crazy elongated.
