I ordered my FWF kit from Jabiru today. I will be using a Sensenich ground adjustable prop. Pete at Jabiru says the wood prop will perform better, I don't know why it would but that's what he says. I will be getting a carb heat and cabin heat box and an oil recovery system. I also ordered a 3300L Data plate which will limit the eng to 2850 max continous RPM. That should keep the S19 speeds in the LSA catagory, if not I can adjust the prop to comply. I also got a video on the install an it's been very useful.
