Located where the exhaust pipe needed to be then cut two holes in muffler. Installed tail pipe and had it welded in place. Installed muffler and cabin and carb heat shrouds to see how they fit. I have a couple of options here and the final placement is not yet determined. Fit the air ducts to the cylinders and started on the front baffles.
