RANDY'S WEB SITE
S-19
Oil Cooler
Installed oil cooler. Drilled angles and fitted spacers to oil cooler. Fabricated upper mounts. Drilled mounts, deburred and installed.
Machining the parts
Plans don't say to but I needed to radius the top edge of the fitting
Installled
S-19 Home
1515
Aft Fuselage
Aft fuselage
Center Fuselage
Construction Tips
Cowling
Fuel tanks
172
FWD Fuselage
HorizontalStabilizer
Inspections
Instrument Panel
Phase I flight test
Vertical Stabilizer
Wheel Pants
326
Workshop
