RANDY'S WEB SITE
S-19
Voltage regulator and shunt
Installed the voltage regulator and ampmeter shunt. I hooked it up so it will be a loadmeter. Turned on the master and avionics master and I measured 4 amps load which is not bad at all. Load meter went up to 6 amps while transmiting on the com.
Located and installed voltage regulator
Located and installed shunt
S-19 Home
1515
Aft Fuselage
Aft fuselage
Center Fuselage
Construction Tips
Cowling
Fuel tanks
172
FWD Fuselage
HorizontalStabilizer
Inspections
Instrument Panel
Phase I flight test
Vertical Stabilizer
Wheel Pants
326
Workshop
