Continued installing and connecting engine sensers and probes. Settled on a routing on the wires then connected the CHT,EGT, oil temp and the oil pressure wires to the D120. Turned on the Dynon and checked the probes. CHT and EGT all read 73 or 74 degrees which is the temp in the hangar. The oil temp read 65 which is about 10 degrees cold. I will check this out later. Connected the mag wires and the starter solenoid and checked mag switches and starter.
Left side CHT and EGT probes
Right side
The bundle of wires will follow the top of the motor mount and split off to go to systems
