Spent quite a while looking at the fuel tank and deciding how I was going to locate the fuel sending unit. I decided that the arm should go outward toward the tip. This way I believe the gage will show full about one gallon short of being full and empty with about one half gallon left in the tank. I also bent the rod to keep it from hitting it's upper limit. Drilled a hole in tank and modified the retainer so I could get it through the hole. Located the sender and transfer drilled the mounting holes. Located all of the parts for the fuel tank then drilled the pickup tube and flattened the end. Modified the retainers for the fuel drains.
