Brief Description: Insp plates pitot tube ali flap hinges
Finished transfer drilling.Removed wing tip skins. Removed clecos fron leading edge, fliped wing over and drilled for inspection plates then removed leading edge skin. Modified pitot bracket and installed pitot tube then removed. Cut lower skin opening for fuel tank. Placed fuel tank in bay and checked location hole in the skin for the fill opening and scuper. Removed tank. Started making aileron and flap hinges.
