RANDY'S WEB SITE
S-19
Building up spars
Located the inner and outer bellcrank brackets and the tie down and support brackets. drilled deburred and edge polished. Primed spar then assembled.
Used a bolt to line up brackets
Bolted and riveted in place
Primed spar
S-19 Home
1515
Aft fuselage
Aft Fuselage
Center Fuselage
Construction Tips
Cowling
Fuel tanks
172
FWD Fuselage
HorizontalStabilizer
Inspections
Instrument Panel
Phase I flight test
Vertical Stabilizer
Wheel Pants
326
Workshop
