While searching for an exit for the left wing fuel line I discovered that the aileron servo bolt would interfere with the aileron pushrod with the stick full aft. I removed the bolt and turned it around for more clearance. It clears ok now but I will use a shorter bolt and thin washers for more clearance. Layed out the wing root faring and found the leading edge. Bent fairing around a one inch piece of PVC pipe. Drew a line and trimmed to the contour of the fuselage. Made a mark .2 " from that edge and trimmed. Marked holes and drilled then drilled and clecoed to wing.
With the stick full aft servo bolt rubbed pushrod. Turned bolt around for clearance.
