I wanted a change so I decided to install the wings. Very tight fit as a matter of fact I had to remove the primer on the spars to get them to slide into the carrythrough. Once I got the angle right they slid right in while rocking the tip up and down. Installed the bolts into the holes. Rolled it outside and took some pictures then back into the hangar. I dropped a plum bob off of the leading edge tip and root on each wing and marked the spot on a piece of tape on the floor. Pulled a string across the lines at each tip and the string fell dead nuts on the two inner marks. I then measured from a rivet on the stabilator to the tip of each alieron. They both measured 145.5 inches. I haven't set the incidencs yet but I am really supprised at how true everything is at this point.
