Installed the right fuel tank pickup, vent and drain. Felt a lot better about the tanks today. The instalation went much better on the second tank. Pressure tested the left tank and discovered that the seal alone will not work. I had very slight leaks around two screw heads. I will have to use some sealer on the threads. I'm waiting on some screws that have the head drilled before I do the final install of the sending units.
